How to display properties of a selected cursor when several cursors are available?
I have a list of 8 cursors and would like to show the information of one cursor (which the user has slected) in the cursor legend of the graph. But I dont want to expand the whole cursor legend until all cursor properties are visible because it occupies too much space in the front panel.
How do I get the index of the cursor the user has selected? I tried the "selected cursor" property but when I moved different cursors its value didnt change!
(2,974 Views)
I don't think it's possible to chagne the actual cursor legend. It is simple to create your own for just the active cursor. I've attached an example in LabVIEW 7.
(2,974 Views)
Hi, Dennis!
Thanks for your help 😉
That was exactly what I needed! My solution was pretty close to yours, but I only forgot to make the "selected cursor" the "active cursor" thats the trick!
Thomas
(2,974 Views)
Hi Dennis!
Sorry to disturb you again 😞
It seems that your soulution doesnt work when you add an envent structure to the while-loop.
Do you have an idea why this is not working?
(2,974 Views)
Try putting the code for updating the cursor info inside the timeout event with a small timout value and see if that fixes your problem.
(2,974 Views)
Splendid 😉
Thanks again!
(2,974 Views)
