04-27-2021 02:07 PM
I created a VI that makes a HTTP request to a weather API, and I’m trying to display some information. So far I've only been able to display values, but I also want to display the weather description from the code. When I use Match Regular Expression the rest of the code is displayed, and I only want to display the weather description "Haze", or any other weather description. How do I get the VI to only display what's in the [""]
04-27-2021 02:37 PM
Obviously, you are doing something wrong but we cannot tell from a picture. Please attach your VI and a sample of the full received string or a valid URL. I am sure there are significantly better and simpler ways to do all this.
04-27-2021 03:16 PM
{"request":{"type":"City","query":"Chicago, United States of America","language":"en","unit":"m"},"location":{"name":"Chicago","country":"United States of America","region":"Illinois","lat":"41.850","lon":"-87.650","timezone_id":"America\/Chicago","localtime":"2021-04-26 20:35","localtime_epoch":1619469300,"utc_offset":"-5.0"},"current":{"observation_time":"01:35 AM","temperature":23,"weather_code":116,"weather_icons":["https:\/\/assets.weatherstack.com\/images\/wsymbols01_png_64\/wsymbol_0004_black_low_cloud.png"],"weather_descriptions":["Partly cloudy"],"wind_speed":20,"wind_degree":170,"wind_dir":"S","pressure":1006,"precip":0,"humidity":31,"cloudcover":25,"feelslike":25,"uv_index":5,"visibility":16,"is_day":"no"}}
04-27-2021
05:27 PM
- last edited on
05-07-2026
05:20 PM
by
Content Cleaner
I strongly recommend to remove the words "FINAL" from the file name of a draft that's not really working well.
You can remove all that duplicate code by using arrays and loops. You can eliminate the extra temperature indicators by showing the digital display of the thermometers.
Adding cosmetics to the front panel should be the last step.
Your string looks like JSON, so you might be able to use these tools. (I am not familiar with them).
Even without that, you can do some rudimentary processing e.g. as in the attached. I show two ways to get the numeric values and you can focus on one. You can get rid of all code in the middle and use the output of the lower code to get the numeric values, of course.
