How to display text on graph
hi,
I am recording action taken on front panel e.g. when clicked on button it ll be recorded and writting it in word file. now i want to display that text on graph.for example on i pressed OK button at perticular time say 5th second ,it should be displayed on that perticular time on graph. is it possible?
Thank you
gak
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,592 Views)
Hi Gak,
Thanks for the post and I hope your well.
The best example I can give is to look in the NI example finder and search cursors, there is a vi called Programmatically annotate a graph.vi. This sounds like you what your after.
This is done by using the Annotation List property for a graph.
Hope this helps,
Kind Regards
James Hillman
Applications Engineer 2008 to 2009 National Instruments UK & Ireland
Loughborough University UK - 2006 to 2011
Remember Kudos those who help! 😉
(3,566 Views)
Hi gak,
You can use annotation list to write text to graphs at a particular location. see the context/labview help more information.
Hope your query is solved.
regards,
Vaibhav
.......^___________________^
....../ '---_BOT ____________ ]
...../_==O;;;;;;;;_______.:/
.....),---.(_(____)/.....
...//____//......
..//____//......
.//____//......
(3,534 Views)
