How to display the units of parameters in the control
I have a simple query related to display the units in controls.
The procedure is right click on the control > select display format > Advanced editing mode. In that a field called format string, here i'm giving the units related to parameters. Now I have to enter "sec2"in that field. How to give the suffix value.
Please help me.
S Nagaraju.
Message 1 of 8
(6,073 Views)
Right Click and select unit label
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 8
(6,061 Views)
My question is how to put ("sec2" ) suffix 2 for that label.
Message 3 of 8
(6,045 Views)
Why aren't you able to just edit the display format and edit it to enter the units you want?
If you want to programmatically set the display format, there is a property node called Format String you can write to.
Message 4 of 8
(6,041 Views)
Dear sir,
I wnant the square value should be displayed like as attached.
Message 5 of 8
(6,026 Views)
Accepted by topic author Sonti_11532
After Sec enter \B2 in '\'-codes display and switch back to normal display.
Ref: https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Subscript-and-superscript-fonts/idc-p/920208/highligh...
uday
Message 6 of 8
(6,019 Views)
@Sonti_11532 wrote:
Dear sir,
It would have been helpful if you said that in your original post.
Message 7 of 8
(6,011 Views)
To enter any ASCII character in the display format dialog box at edit time, you can use the alt key and number pad.  For the superscript 2 which Uday stated was \B2,  you can hold the alt key then type 0178 on the number pad.  (B2 hex = 178 decimal)  On the number pad, you always need to front fill the number with zeroes to enter it as 4 digits.  The degree symbol ° is Alt 0176.
Message 8 of 8
(5,997 Views)
