How to display two waveforms in one waveform chart?
hellow!anyone can tell me how to display two waveform together in one waveform chart? thanks!
(4,150 Views)
You can use a 'build array' tool.
(4,149 Views)
An easy way to tell how to make multi-plot charts and graphs is to hold your mouse over the chart/graph terminal on the block diagram and make sure Context Help (Help >> Show Context Help) is enabled. This screen will tell you how to connect the indicator for a multiple-plot display.
You might want to take a look at my attached screenshots of a working multi-plot chart.
Hope this helps!
Liz F
(4,149 Views)
