How to distinguish numerics and characters in a string
I'm looking for a simple way to do it or any built-in subVIs that can do this.
I have 3 strings "1234c", "ab3dc". "xya", I want to identify the ones that have numbers and retrieve all numbers. So one important step is to distinguish the numeric characters and non-numeric characters. How can I do it in Labview with built-in subVIs?
ThanksSmiley Happy
Arnold
(4,003 Views)
Hi mugger,
Use match Pattern from function palette>>String functions.
Read help file you will come to know about its function.
You can find A sequence of one or more digits and characters using this function.
Best Of LuckSmiley Happy
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,995 Views)
Accepted by mugger
[0-9] looks for a number, "+" makes the search look for 1 or more of them (it's "greedy", so it'll get as many as there are.)  I added one more string to your list to show that Match Pattern will match only the first instance of a number.  If there's a chance that you'll have data like the last element you'll need to run it in a loop.  Decimal String to Number can also work if a digit is the first character it finds.
Jim
(3,966 Views)
How are the strings created? do you have the control to structure these?
(3,934 Views)
Thanks buddy, that really helpes alot!
Another question is I have a XY graph with multiple cursor on it. I'd like to drag cursors, one at a time. So my question is how can I let labview know which one I drag? any idea?
Arnold
(3,882 Views)
You should start another thread for this question.
Jim
(3,856 Views)
For single characters there is the "lexical class" node under comparison. I'm just mentioning it since it's not a very well known node.
(3,836 Views)
