How to do String Filtration with don't cares...?
I need a help on getting string filtration with don't cares. Attached a VI for ref.
If any one has string parsing expertise; i need your help.
SB_LV
(3,831 Views)
Accepted by topic author Blessing_Star
Another fun one
 see the help file for regular expression
The Default case in the case select is
(3,817 Views)
Hi Jeff,
Thanks for your help. It's really appreciated.
Any workaround with don't care values, if i add multiple xx (Ex.: xxxx8040xx or xxxx8040) in the filter. I've attached a VI  for reference.
SB_LV
(3,793 Views)
Just scan the search string and replace your "don't cares" with a regular expression "don't care"(period) :smileywink:
(3,774 Views)
How about just use Search and Replace String?  A VI using it is in LabVIEW examples or do a quick drop.  (In strings menu)
(3,764 Views)
