How to do import data from the text file into the mathscript window?
Could anyone tell me how to do import data from text file into mathscript window for labview 8?
MathScript Window openned, File, Load Data - it has options: custom pattern (*.mlv) or all files.
(2,976 Views)
Hi Milan,
Prior to loading data in Mathscript Window , you have to save the data from the Mathscript window (the default extension of the file is .mlv but you can choose any extension). This means that you cannot load data from a text file  that was not created using the Mathscript window.
Please let me know if you have any further questions regarding this issue.
Ankita
(2,962 Views)
