How to do scaling of dynamic data in labview
I am generating Dynamic data from DAQ assistant. DBL values generating from DAQ assistant is between 0-20mA. I want to change range (Lets say between 2-10A) and change DBL values according to range.
(I don't want to change input; It should be between 0-20mA)
What should I do??
(1,598 Views)
Don't use the DAQ Assistant.
Don't use DDTs.
Just:
  • drop a DAQmx Task constant on your block diagram
  • Right-Click and select Create New Task to bring up the DAQmx Wizard
  • Use the Wizard to configure,  test and save your Task, channels and SCALES. Remember to rename the Task, Chanels and Scales.  See Note***
  • Save the configuration. Your Task Constant will now have the Task name
  • Right-click the DAQmx Task Constant again select Generate Code (Configuration and Example)
  • Save the vis and have a 🍩 and .
Give Kudos for anyone who posts a Jing link following that process. The Forums need one!
**NOTE: let's assume a system monitoring your bath
Device0 "CurrentLoops0"
Task "Flow_Meters"
Channels "H20_Hot", H2O_Cold", "H2O_Fill", "Drain"
Scales "GPM_0pt75InchPipe", "GPM_1pt5InchPipe".
Device2 "Therocouples"
Task "Temps"
Channels "Room", "H2O_Fill", "H20_Tub", "RecircOut" <I want a jacuzzi!>
Scales "degC", "degF", "K"
Device2 "DigIO"
Task "Sensors"
Chanels "TowelPresent", "BubblesOn", "Overflow"
Task "Buttons"
Channels "Bubbles", "BoostMode" <hey its a NICE jacuzzi!>, "OrderMartini" <a very nice jacuzzi > etc...
(1,569 Views)
Hey,
Thank you so much for reply 🙂
Okay, I will try doing a you and GerdW explain.
(1,551 Views)
