How to draw a graph step by step ?
Hi, sirs,
Can you tell me how to draw a graph step by step by using Labview 6.0 ? On one step, I create two variables : one variable is used for X-axis, and other variable is used for Y-axis. Can you give me a simple example ?
Thanks a lot.
(2,855 Views)
To graph X and Y variables, you have to use the XY Graph. To make an XY Graph act like a chart in which it updates incrmentally, then there are two shipping examples to look at. One is called XY Chart and the other is Variable-Time Chart XY. Both use a subVI to buffer the XY data and maintain a user specified chart length.
(2,855 Views)
Try this example out.
(2,855 Views)
