How to draw an Intensity graph which x/y coordinates do not match the 2D-Matrix indices and do not be equidistant?
I am trying to draw an intensity graph that do not have equidistant x/y coordinates. These coordinates are not integer and then do not match the indices of the 2D matrix.
I do not want to use a 3D graph because this is not so easy to use for the user as the intensity graph for that purpose.
If somebody know a solution, I will be pleased to heard from.
Thank you in advance.
(3,071 Views)
I think, there is no way to use floating point indices for the 2D-Matrix.
What I would do is to scale the x/y-coordinates.
for example: 0 is element 0,
0.25 is element 1
0.5 is element 2
and so on....
you can scale the X and Y-axis of the graph with the same factor, so that the axes are correct labeld.
I hope this helps..
regards,
Peter Weber
Ni Germany
(3,071 Views)
you can use 3D Parametric Plot to solve your problem. You must tune it to show XY projection of your points, where z coordinate must correspond to some color.
The example is attached.
Good luck.
Oleg Chutko.
(3,071 Views)
