How to draw stock candlestick (open/high/low/close) chart in LabVIEW?
Dear all expert,
1. Does any one have experience on drawing stock candlestick chart (open/high/low/close) in LabvIEW?
2. I try to use ZedGraph (http://zedgraph.org/wiki/index.php?title=Main_Page), but it doesn't seem to work
HM
請給我一個Kudos吧, 如果有解決問題
Message 1 of 12
(14,696 Views)
You may be able to use an XY chart to get the candlestick look by using 3 Y values for each X.
What doesn't work with the ZedGraph control? Using it (related to your other post here), or making a candlestick graph? Have you looked at the demo on the ZedGraph page?
Message 2 of 12
(14,666 Views)
Might be easier to use an excel chart inside labview.
Message 3 of 12
(14,653 Views)
Dear smercurio_fc,
This example really helps me to calrify problem of using ZedGraph, many thanks.
HM
Message 4 of 12
(14,630 Views)
How can I use an excel chart inside LABVIEW?
Anyone knows how?
PataPata
Message 5 of 12
(11,707 Views)
Dear HM,
Were you able to get the stock candlestick chart in LABVIEW using ZedGraph?
If so would you share with me please.
I've tried several times but have not been able to do it.
PataPata
Message 6 of 12
(11,705 Views)
I was trying to do this using Error Bar graphs, as a suggestion from NI, but it just was too clunky, and not quite a good duplication of the goal. So, I dived into ZedGraph, learned a bit of .NET, and the result is attached as a LabVIEW 2012 VI.
My objective was to duplicate the "Japanese Candlestick Demo" from:
http://zedgraph.dariowiz.com/index978b.html?title=Japanese_Candlestick_Demo
+1 to "C. Minnella" for the refresh fix shown in his Refresh.vi posted at:
http://forums.ni.com/t5/LabVIEW/Tickness-Report/m-p/537308#M253544
You will need to install ZedGraph, such as v.5.1.5, as available at http://sourceforge.net/projects/zedgraph/
Ken
Message 7 of 12
(11,358 Views)
Hi HM,
You can try CandleStick xcontrol from here:
http://ikcilab.com/index.php?option=com_content&view=article&id=13:candlestick-plot-indicator&catid=...
Rgds,
K
Message 8 of 12
(11,220 Views)
I downloaded the file, but it is not unzipping please upload the good one
Message 9 of 12
(10,237 Views)
Yeah, after quite a few weeks re-building charting libraries we have built this:
http://www.austinconsultants.co.uk/finance-candlestick-ohlc-graph-toolkit/
Worth checking out and is the best LabVIEW candlestick graph available at the moment.
Cheers
Peter
Message 10 of 12
(8,686 Views)
