How to drive an USB device in LABVIEW using call DLL node!Thanks...
I have a USB device which is not manufactured by National instrument, but it has a dynamic link library (DLL) file. I tried to drive it in LABVIEW using call DLL method.
When the program runs, the error message is pop-up.
“An exception occurred within the external code alled by a Call Library Node. This may have corrupted LabView’s memory. You should have save any work to new location and restart LabView.”
The manual says the function is
Function EasyLaseWriteFrame (CardNumber:integer, DataPoint:pointer, Bytenumber:integer, Pointspeed:word):boolean
The declaration in DELPHI is
var
function EasyLaseWriteFrame (var cardnumber:integer; DataBuffer:pointer; DataCounter:integer; Speed:word):Boolean; stdcall; external ‘easylase.dll’;
Because I am not an expert in DELPHI, how should I correct my call DLL code in LABVIEW?
OS: Windows 98
LV version: 6.1 full development.
Thank you
(4,017 Views)
Read the paper about 'including external code in LabVIEW'. (Help-search the bookshelf)
The hurdles I run into where mostly because of datatypes. Some DLL claim to handle 8/16bit integer but the interface is handling with U32...
And always save before run Smiley Wink
Greetings from Germany
Henrik
LV since v3.1
(4,002 Views)
var
This manual seems confiusing or maybe it is rather confused 😉
VAR parameters in Pascal (and Delphi is still Pascal in its syntax) mean that they are passed by reference. Nothing like this is however visible in the first description of the function.
If it is really a parameter passed by reference you should configure the LabVIEW CLN to use "Pointer to Value" for this parameter.
Also the second parameter is a buffer. It is mandatory that the caller (e.g. your LabVIEW VI) allocates that buffer before calling the function. To do this place an Initialize Array function on the diagram, wire an uInt8 constant to its type input and another constant to its size input specifying the number of bytes the buffer should have. Pass this same number also to the third parameter of the CLN to tell the function how much buffer space it can expect. Configure the second parameter of the CLN to be an Array of type unsigned 8bit integer, et voila.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,982 Views)
