How to dynamically add a plot to a mixed signal graph
I have a mixed signal graph where I am plotting a signal vs. a time axis. I am trying to dynamically add a second plot to this graph against the same time axis (with a different Y scale) but when I build a 2D array and try to wire it into the graph (using a local variable) I get a dimension mismatch error. I know for sure I have done this in the past (wired arrays with different sizes to a same MSG) without any problems but today for some reason I can't seem to solve this.
Am I missing something?
(4,772 Views)
You're writing the multiple plots to a local variable of the graph instead of the indicator terminal itself. The indicator terminal adapts to 1D/2D data to show single or multiple plots, but the local variable can't do this.
Somewhere you need to wire a 2D array to the actual terminal and this should fix your problem. You should really use the terminal instead of the local var anyways.
Cheers
(4,734 Views)
Thanks James,
the problem is I write to this graph in two different parts of the program, first a single plot and then only if the user presses a button I add the second plot (not always since calculating the second plot is very time-consuming).
I have tried to put the indicator into the main while loop of the VI but then the graph is redrawn with every iteration, and I need to define an output for the graph for every case of the case loop that's inside the while loop (if I just set it to "default if unwired" it will be cleared).
I have another graph in the same program where I first send a 2D array (2x1D arrays) and then when the user presses a button I add a third 1D array to that 2D array and plot it by writing to a local variable, but I guess in this case the problem isn't adding a new array to a 2D array but changing the dimension from 1D to 2D.
(4,722 Views)
Accepted by topic author thehun
Yeah, you're probably writing a 1D array somewhere that's causing it to only accept 1D. To fix your above problem, just put a Build Array node in wherever you have a 1D array and it will just be a 2D array with only one row of data.
 To add a plot to your current plots, your screenshot above should work once the plot knows to accept 2D arrays.
Reading from a local variable, changing something, and then writing to it again can lead to a lot of issues down the line. Race conditions are a pain in the butt, so getting rid of that type of stuff is good to do early on. I haven't seen the rest of your code, so I don't know how you're handling this, but just keep that in mind as you're adding to your software.
Cheers
(4,715 Views)
Yep, that did the trick, thanks again! Smiley Happy
(4,692 Views)
