How to dynamically enable or disable a control's runtime shortcut menu?
Is there a way to do it?
I need to disable a control's runtime menu while my VI is running and then enable it at other point of time.  All the way, I can make use of the default menu items (Reinitialize to default values, Copy data etc..,) for the control and I don't have any customized menu items.
Ajay MV
(4,620 Views)
Hi Ajay,
as a quick & dirty way you could use a filter event for mouse clicks. When you want to disable the right-click menu you filter the right-click mouse events…
(4,612 Views)
Register for the control's "Shortcut Menu Activation?" filter Event and selectively discard it.
(4,601 Views)
Thanks for the reply.  That will give a bad impression for the end user.  He/she may think like my application doesn't reponse to the available options.  I specifically want to greyout selective options.
Ajay MV
(4,516 Views)
@GerdW wrote:
Hi Ajay,
Smiley Very Happy  Thats nice dirty idea.  But it might give my end-user an impression that my application doesn't respond to the given options.  I specifically want to greyout the right-click menu.
Ajay.
Ajay MV
(4,513 Views)
You can dynamically load different run time short cut menus. ( I use if for language changes)
Maybe you could have your normal menu, and then load an empty menu when you want to get rid of the menu.
Edit: oops, didnt read the question!
(4,507 Views)
