How to edit plot legend menu?
Hello
Is it possible to customize plot legend menu? Or to export some icons from it?
(3,363 Views)
But can explain in a bit more detail??
(3,340 Views)
I want to allow user to work with plot legend menu without some items, unusable in my application. Or create my own menu, but with items presented by the same pictures as in plot legend menu.
(3,324 Views)
Err-
There are ways to modify the shortcut menu for most front panel objects, but not with the plot legend. As an alternative, you can disable the plot legend and create your own custom controls for the user to manipulate (and just use property nodes). This is more tedious, but may be the only way to get it done.
Xaq
(3,305 Views)
