How to embed windows app into labview frontpanel
how can i integrate any open Windows appication in a labview frontpanel. In the attached vi it opens calc and brings to front. But i would like it to be on the labview frontpanel.
(5,204 Views)
  1. Never use a Stacked Sequence Structure!
  2. (Almost) never use an "ordinary" Sequence Structure -- the Error Line is in (most) LabVIEW Functions for a purpose -- use it to sequence your code.
  3. Have you tried running Calc in a sub-Panel?  It's not clear why you are doing this ...
Bob Schor
(5,156 Views)
(5,146 Views)
Windows has Parent and Child functions that can allow for a window inside a window.  I wrote some demo code a while ago on how to embed Notepad in the front panel of a VI.  This was part of some code I posted on LAVA on the Multi Panel Interface which creates a dynamic number of things on a front panel that can be running and updated independently.
http://forums.ni.com/t5/LabVIEW/How-to-run-an-exe-as-a-window-inside-a-VI/m-p/3113729#M893102
(5,127 Views)
