01-05-2015 10:05 AM
Could someone please tell me if there is a function in LabVIEW available that would enable a signal to be generated by the function generator whenever a high input is detected at the TRIG terminal of the NI virtualbench. Also, how can I read-in or output a trigger signal from the TRIG terminal on the virtualbench using LabVIEW functions?
Thanks for your help,
Rowan
01-05-2015
10:25 AM
- last edited on
06-16-2025
02:50 PM
by
Content Cleaner
You should really post your question to the VirtualBench board - https://forums.ni.com/t5/VirtualBench/bd-p/340
01-09-2015
05:36 AM
- last edited on
06-16-2025
02:50 PM
by
Content Cleaner
Hi rgriffin,
Have you had a look at some of the tutorial available "How to Automate VirtualBench in LabVIEW" and "VirtualBench: Generate Standard or Arbitrary Waveforms With the FGEN". You can take a look at which instrument you are using and see if this helps.
Kind regards,
GajanS
