How to enable mobile hotspot of PC through LabVIEW ?
Hai guys ,
I tried to enable the mobile hotspot of PC through LabVIEW , please some one help me out & suggest to solve
thanks in advance
Regards
GOBI S
(2,167 Views)
Hi Gobi,
What have you tried?
Where are you stuck?
Mind to attach your VI?
(2,166 Views)
 I tried manually to enable mobile hotspot using cmd prompt ( creating batch file ) , its not working & I'm struck with that
(2,157 Views)
Hi Gobi,
Did you actually try your commands in a batch shell? Did you read the help for that netsh command?
Two immediate problems:
  • You need admin rights to actually set the hosted network.
  • The "KeyUsage" parameter is wrong.
(Both is explained by the netsh help text!)
(2,154 Views)
Hai GredW,
Please Suggest some other solution & I need to enable the mobile hotspot through LabVIEW
thanks in advance
(2,151 Views)
Hi Gobi,
@Gobi1230 wrote:
Hai GredW,
Who is "GredW"?
What's wrong with my last comments?
Why don't you read the help for the netsh command to learn about its options?
(There is no way around the requirements of the admin access rights…)
(2,120 Views)
