How to enable the high voltage range in E364Xa Power supply
I am using the E364Xa power supplier sample code downloaded with the E364Xa driver from NI website. I need the ouput voltage in the high voltage range. please see tha attachment. But the sample code got an error when the ouput voltage is higher than the low voltage range. The default setting for the equipment is low voltage range. Does anyone konw how to enable the high voltage range before setting up the output voltage?
(3,071 Views)
Accepted by topic author Justin2007
Problem solved. I found the output range control VI.
(3,059 Views)
