How to establish bluetooth communication between Labview and Arduino
Is it possible the bluetooth communication between and arduino and a PC or PDA with Labview? Have you done any similar communication (for example using any ATMega or PIC microcontroller)?
(4,670 Views)
Hi Ima_P,
As long as you are able to implement the Bluetooth communication on the Arduino side, you should have no problems since LabView provides a library for Bluetooth communications. This library is based on the Windows Bluetooth Stack. Check out the following link:
https://www.ni.com/en/support/documentation/supplemental/06/developing-bluetooth-applications-with-l...
Best regards.
(4,631 Views)
