How to estimate damping factor
Hey guys,
anyone can help me to find the way to estimate the damping ratio of the posted waveform?
Thanks in advance.
Notes: Run damping.vi and then choose wave10.txt
Andrea
(7,219 Views)
Andrea,
1. Find peaks of oscillations.
2. Fit an exponential to the peaks.
3. Damping is exponential coefficient.  You may need to adjust to your time scale.
Your signal is clean enough that this works well.  I used the Peak Detector VI with the threshold set to .05 and the width to 5.  The default width is 3 but you have a bit of noise so I widened the peak a bit to reduce the chances of "detecting" multiple peaks due to noise.  Note that it does get multiples at 1439, 1442, 1444.
So that I do not need to read the file every time I run, I made the Waveform Graph value default and then converted it to a control.
Lynn
(7,214 Views)
