How to execute an exe while LV is running?
Hi
Currently I have an exe file (from VB) and wanted to execute it while my LV is running.. How can I do it? I've already searched around the net but couldn't find any way to execute it.... I understand that the System Exec.vi would help me on this but no example of how to run the exe... THANKS!!!
(3,972 Views)
(3,967 Views)
Is this the only way to run / call an exe file in LV? I don't wish to see the MS DOS prompt before executing. Any advise?
(3,947 Views)
You can run it minimized.
________________________________________________________
Try to make everything Automatic
(3,945 Views)
You can minimize the DOS box with the Run Minimized input.
Also, there's another option:  use the ShellExecute Win32 API call.  See this thread for an example VI using this approach:
http://forums.ni.com/ni/board/message?board.id=170&message.id=169615
-Khalid
Message Edited by Khalid on 03-19-2006 07:35 PM
(3,942 Views)
Run it minimize???? HOW??
Anyway, thanks Khalid for the reply
(3,925 Views)
Hello 222,
the "System Exec.vi" has a "run minimized?"-input! Just switch on the online help (Ctrl-H)!
(3,921 Views)
