How to execute part of diagram only once
Please see attached VI. I want part of diagram outside while loop to execute only once, when button goes from OFF to ON.
(2,782 Views)
Hello!
I have edited your VI to behave the desired way.
Find the same attached.
Hope this helps!
- Gurdas
Gurdas Sandhu, Ph.D.
ORISE Research Fellow at US EPA
(2,758 Views)
I think you'll find some bigger problems in your code. If you only want it to execute once, you need to let your while loop run. The problem now is that you're wiring the stop condition from outside the loop, so the while loop stops after the first time it runs. Here's another way. It's not ideal either, but it should work.
___________________
Try to take over the world!
(2,753 Views)
