How to exit a while loop ?
How can I exit a while loop ?
I'm new to Labview and I've tried to do my first Labview programm.
I've taken an old example, a sieve for prime numbers. The old Erasthotenes sieve.
Similar to that (Visual Basic Example):
While (l <= k) and Teiler <= Math.Sqrt(i)
       Teiler = TeilerArray(l)
Message 1 of 13
(8,235 Views)
While (l <= k) And Teiler <= Math.Sqrt(i)
       If i Mod Teiler = 0 Then
            IstPrim = False
            Exit While
       End If
       l = l + 1
End While
So, how can I model that "Exit While" ?
Message 2 of 13
(8,227 Views)
Use the conditional terminal of the while loop to stop it, based on a logical conditional check for your code.
- Partha ( CLD until Oct 2027 🙂 )
Message 3 of 13
(8,223 Views)
Where do I find this "conditional terminal" and what is it called in German ?
Is it "Haltepunkt" in the context menu of the while loop ?
How do I use the "conditional teminal" ?
I use the german version.
Message 4 of 13
(8,202 Views)
Pl see the attached snapshot.
Sorry, I dont know German.
Message 5 of 13
(8,199 Views)
This is not an exit statement.
See below.
http://zone.ni.com/devzone/cda/tut/p/id/6285
As it seems to be only the for loop supports an exit statement.
"Conditional terminal" in the context menu.
Message 6 of 13
(8,194 Views)
Hi Hans,
it is an exit statement. If you connect the correct value to it, then the loop stops.
You can use a case structure to don't run other code if a special "stop event" occur.
Mike
Message 7 of 13
(8,183 Views)
Accepted by topic author HansWerner
Hans,
What you have linked is for the FOR loop, what I had attached is for the WHILE loop. Smiley Wink
Only the type of the loop is different, but the concept or logic is the same for both. Smiley Happy
Message 8 of 13
(8,175 Views)
Ok, I will try this.
I've thought that this is only a button to stop the loop.
Message 9 of 13
(8,144 Views)
Yes you are correct, what is the differene between 'exit' and 'stop'
Ton
My LabVIEW Ideas
Message 10 of 13
(8,125 Views)
