How to expand a Case Structure so it adds other code?
How do I expand a case structure so that it adds other code instead of pushing it around?
For example I want expand the structure below so that it includes the increment vi.   This is a simplified example.  Normally I want to add (or remove) a lot more code, and disconnecting and reconnecting a bunch of wires is tedious and risky.
(1,481 Views)
This doesn't make a lot of sense. Would you want the code to be added to all cases or just one? Typically the number of tunnels can change and how should it decide what connects to where?
(1,462 Views)
It makes perfect sense.  The code would go in the selected case, if the LabVIEW developers wanted it to be intuitive.
(1,443 Views)
Accepted by topic author jncuevas
It would not be intuitive for me. It is quite rare for me to want that behavior. 99% of the time I move a case structure I want to add room, not move stuff inside the frame. I would certainly not want that to be the default.
There isn't a way (as far as I can tell) to have it wrap new stuff in as you expand it, BUT you can move the structure, then just drag the other stuff inside. LabVIEW does a pretty good job of maintaining wire connections over border moves, so you should be able to just drag it in without needing to disconnect and reconnect all the wires.
(1,439 Views)
Caveat here, the auto-rewire thing was only present in LV 2015 and newer.
Bill
CLD
(Mid-Level minion.)
(1,406 Views)
Dragging the increment in, rather than expanding the structure is the solution.
If there's too much to drag in, you're doing it wrong.
(1,341 Views)
