How to export a table and array as image?
I mentioned the tab control in passing. I get the error message regardless of tab control or not.
I have one flat box surrounding three objects in my VI and this box is NOT inside the tab control at all. It is sitting outside.
I still get this error shown in my previous post.
Message 11 of 17
(1,817 Views)
Post your VI, or at least the part that gives the error.
Message 12 of 17
(1,816 Views)
Hi Darin
The main VI is untitled18.vi
It calls a bunch of sub VIs all included in the zipped file below. I also included one sample data file (file1.txt).
Run the main VI and select file1.txt.
Data and everything plotted is fake.
Message 13 of 17
(1,804 Views)
I stripped everything out except the exporting.  The main problem was the position of the tab, negative values are a problem for the image subset VI.  I moved everything close to the origin and made a few mods to export the images.
Message 14 of 17
(1,798 Views)
Thanks Darin. Could you please save in 2011 version. I don't have labVIEW 2012.
Message 15 of 17
(1,791 Views)
Here it is in LV11.  Notice that I do not discriminate and simply export all of the decorations, which includes the Free label in the first tab.  You should be able to sort this out with the other information in this thread.
Message 16 of 17
(1,779 Views)
I think it should be easy like that "Array>Create>Invoke Node>Get image"
Message 17 of 17
(1,706 Views)
