How to extract 10 elements and rotate them
I'm new in LabVIEW.
I am getting data from a wavemeter and I already did the code to handle data from it such that the frequencies are converted into numbers. All this is placed in a while loop and by using auto indexing data is stored in an array. My problem is now that I want only 10 elements in my array and the elements must rotate as new numbers enter the array.
It is easy to make an 10 element array in a for loop, but that is not what I am supposed to do. I need 10 elements but they have to change. Also I would like to see the elements in the frontpanel while the VI is running, how do I do that?
(3,149 Views)
Hi DTP,
try something like this:
(3,120 Views)
Or you could just use the Data Queue PtByPt and it does it all for you.
(3,113 Views)
Thank you so much! Should I then wire my numbers where the random number is wired?
(3,110 Views)
Yes, sure! (To both of you. :D)
(3,107 Views)
