How to extract data from cluster of component levels?
I use harmonic analyzer function to read out the component levels cluster, which cotain data for channel 0 and 1
 but have problem reading out the fundamental component for each channel ( array element 1). Pleas help.
(3,062 Views)
Use the Unbunble function found in Cluster palette.
In the future, don't post a Word document.  Instead create a png picture and post it, or use the LV2009 code snippet.
- tbob
Inventor of the WORM Global
(3,061 Views)
Accepted by topic author dot55
Yes! I need an index function before using unbundle by name to extract desired data. thx
(3,049 Views)
Uhhh....  you marked your reply as the accepted solution.  Give yourself a cigar!!!! Smiley Very Happy
Instead of using index, wire the array of clusters to a For Loop.  Set indexing enabled on the input terminal.  Then you can build an array of all the elements if you wish to handle it that way.  You can get an output array for each element in the cluster.  Not sure if this is desirable to you, just a thought.
Message Edited by tbob on 04-20-2010 03:46 PM
- tbob
(3,042 Views)
Sorry ! It was accident since this my first time using this forum.
you are deserved a cigar!  Thanks for the solution.
(2,997 Views)
