How to extract elements from an array and build them into a new array?
So I have a 1D array of 30 elements. I want to extract the contents of the 5th, 6th, 9th, and 20th elements and then store that info in a new array. Is there a way to do this?
(2,977 Views)
You just need to use the Index Array function to get the elements you want and wire them to a Build Array. You've been a user long enough that this extremely basic code would be second nature.
(2,971 Views)
