How to extract encoder phases (A, B, Z channels) from counter?
I have a simple question that I am having trouble answering. My question is, is it possible to extract the raw data (meaning phase A, B, Z) from the VI attached? I understand that the angular position of the encoder, which is calculated using channels A and B, is the data that is being displayed, but is it possible to also display the values of phase A, B and Z in volts maybe? Or in any other way?
Thank you,
r15
(4,342 Views)
You are essentially reading digital signals, so there wont be any point in displaying the voltage I dont think.
Have you tried these links?
http://zone.ni.com/devzone/cda/tut/p/id/7109
http://www.ni.com/gettingstarted/setuphardware/dataacquisition/quadratureencoders.htm
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(4,327 Views)
I have read many articles on ni.com and I understand I am reading digital signals and there is no point, but I would like to be able to extract the values of phases A, B and Z for calibration purposes. My question is is it possible to retrieve these values along side the angular position of the encoder.
I just need the values of the 3 phases at any instant during the running of the program.
Thank you,
r15
(4,316 Views)
You could read them as three different counter lines and calclulate the angular position using the formula in the link posted before.
(4,312 Views)
What hardware are you using?
How many counters do you have?
Ion R.
(4,292 Views)
I am using three similar quadrature encoders with the following part number: E50S8 - 1000 - 3 - T - 5
To decode these encoders, I am using the NI USB-6341 which has 4 counters.
I attached the datasheet for the encoder.
r15
(4,274 Views)
At this moment I would agree with aCe and use counter line to read signal A,B and Z.
(4,252 Views)
