How to extract the xcontrol output
I created one xcontrol for pressure sensors . I am able to display the output correctly but i could not able to use the output for other inputs .
how to extract the xcontrol output
for clear understanding please see the attached vi testing .
(3,099 Views)
Hi Nagaa,
you only get the input data - the same value as could be read from the wire directly...
But:
Your XControl could export some more properties and methods. That way you can easily read also those converted values: create a property "converted value" (or named similar) that gives back the displayed value. All that is explained in the help for XControl creation...
Btw.: Did you ever thought about using units display abilities of LabVIEW? LabVIEW supports atm, bar, Pa, psi, Torr, mHg. But who the hell is using other units than given by SI?
(3,093 Views)
I always measure velocity in furlongs per fortnight Smiley Tongue
Units are very powerful, and like any great magic, can result in serious unintended circumstances.
I've tried them a couple of times and decided they were more difficult to use than the value provided. Maybe it's better now, but I'm still on LV 8.6 😞
http://forums.ni.com/t5/LabVIEW/Why-do-very-few-programmers-use-LabVIEW-unit-labels/td-p/1119746
(3,083 Views)
Thanks for replying mr.
As u suggested to add more properties i tried some trial and error methods but its not coming so please help to compleate remaining part
Thank you
raja
(3,068 Views)
Though I have never used LabVIEW Unit labels, I am interested to know what unitended circumstances it could have?
-FraggerFox!
Certified LabVIEW Architect, Certified TestStand Developer
"What you think today is what you live tomorrow"
(3,062 Views)
Hi Fragger,
just one classic circumstance: try to square a value with a unit!
- What's the result of squaring "1m", when LabVIEW takes over?
- What's the difference when using a simple multiplication function instead of the square function?
(3,060 Views)
