How to extract transient oscillation stability time.
I need to get an approximate maximum stability time from all of these transient oscillations in this test data. I can see that the maximum stability time is a little over 2 seconds. I�m sure there is a way to extract this information from this data but cannot seem to come up with the method. Any help would be greatly appreciated.
(2,780 Views)
How do you define "maximum stability time?" Since the data is both noisy and has different transient behavior on rising and falling transistions, the definition can have a significant effect on the measurement. I might take the mean of the last ten seconds before a transition and then calculate the time from first crossing 2*Standard Deviation from the mean to the last crossing.
(2,780 Views)
Defining the �maximum stability time� for this test data has been a pain from the start.
The spec reads, ��.shall stabilize with in 5 seconds� with no indication of what stability really is, and then requires a recording of the maximum stability time of all transitions. One 30-minute test results in 120 transitions. I was hoping to be able to use a VI to extract this information from my data and didn�t want to �reinvent the wheel� if this has already been done before. Thanks for the reply.
(2,780 Views)
