How to fill in the area under a curve between 2 user select cursor points
Can someone please tell me how to fill in the area under a curve between 2 user selected cursor points? Attached is a simple curve, I want to fill in the area between cursor 0 and cursor 1.
(3,414 Views)
Please don't post bitmap images to the forum.  It is way too large.  Although your file extension says .gif, it is not a .gif.  It is actually a .bmp with the extension changed to .gif.Smiley Mad
(3,390 Views)
Hi mhdp,
you can create a second curve with NaN values outside your cursors and the real values inside. Use another color and plot it to the same indicator.
Hope it helps.
Mike
(3,381 Views)
Sorry about the bitmap image, that was my first post on this forum, I had trouble attaching the file.
Mike, thanks a lot for your suggestion. I will try it.
(3,362 Views)
