How to find COM port for a specific USB device
Hi dave,
              when you connect your USB and you have insalled the usb to serial driver for that USB then it will automatically read in device manger. Here is the simple VI I wrote long back.
Let me know if you want some help
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 21
(10,350 Views)
I am using CVI, not labview.  Is there a way to search windows for the USB serial number and obtain the comport address programatically?
Message 12 of 21
(9,923 Views)
If you are using cvi, then post to that board.
Message 13 of 21
(9,910 Views)
Sorry for once again resurrecting an old thread but I came across this looking for an answer.
To find COM port numbers of FTDI Chips see my post here:
http://forums.ni.com/t5/LabVIEW/Finding-FTDI-Chip-COM-Port-Numbers/td-p/3123726
Message 14 of 21
(9,010 Views)
Hello Matthew,
I am having visual c++ code that enumerate all USB devices and I have attached a usb-to-serial but I cannot get the com port (com4)..
I have the usb hub/port, do you know a way to get com port from hub/port from Windows Driver kit or something else that work with visual c++ (win32)?
Thanks so much,
Message 15 of 21
(7,857 Views)
Try this.
Message 16 of 21
(7,837 Views)
Oops. Forgot all the subVIs.  Here's the whole package.
Message 17 of 21
(7,836 Views)
If your FTDI serial-converter device reports a serial number, then Windows will always assign it to the same COM port (if that COM port is available).  If it does not report a serial number, then Windows will assign whatever COM port number is convenient.
Message 18 of 21
(6,525 Views)
 sir,
pls send a 2013 version of this code
Message 19 of 21
(6,027 Views)
@dineshmeena wrote:
 sir,
You wrote "sir", but you don't indicate which "sir" you are referring to.  Are you referring to me?
You wrote "this code", but you don't mention which code.  Are you referring to "Find Specific USB Com Port.llb"?
Message 20 of 21
(6,006 Views)
