How to find QMG 220 IP?
Hello everyone,
I am using QMG 220 but I have a problem in finding its IP address.
I already tried quadera software but it also not showing any IP.
furthermore, I used advance IP scanner by setting the different IPs network range but still, I can't get IP.
Help needed!
(2,906 Views)
This does not sound like a LabVIEW question. Please explain.
Seems a plain networking problem. Is everything connected? All cables OK? all IP addresses configured correctly and on the same subnet? etc. etc.
(2,898 Views)
I think your problem is related to the ethernet configuration, have you tried using NI MAX?
(2,609 Views)
