How to find all property nodes for a control?
Hi all,
I know I can click on a control on the front panel, and do find->property node, and that takes me to what I would term, the 'first' property nodes in the block diagram.
I have many of them scattered throughout...how do I find the other nodes in the block diagram? Is there a similar mechanism to when you search a document for the instance of a word, if finds the first one and you hit enter again to find the next one?
I'm trying to find a good way to find all the property nodes for an object within a block diagram.
Thanks in advance,
cayenne
(4,241 Views)
cayenne,
I think control-G or command-G, depending on the OS takes you to the next of the found set.
Lynn
(4,235 Views)
@johnsold wrote:
cayenne,
Lynn
Thank you, I'll give it a try...both of them.
I'm currently running LV 2011 on Win7 within a VMWare vm...running on OSX.....
C
(4,231 Views)
If you do a right-click...find...property nodes and there is more than one result, you get the following dialog. Sometimes it helps to read what it says right there! 😄
It tells you that Ctrl-G and Ctrl-Shift-G will go to the next, or previous occurrence, resp.
(4,217 Views)
