09-25-2007 03:32 AM
09-25-2007 03:38 AM
Sorry to add more seperately here...
I did open the missing VIs directly from the ...\VI.llb\... folder itself, & everything works fine. I mean the VIs themselves open without any corruption happened & also function normally when run there.
I dont know ways to fix this problem.
Anybody please shed some light on me...
09-25-2007 04:14 AM
09-25-2007 04:46 AM
All these days LV doesnt put them in the "data" folder except our 2 other own dlls built in VC++ for our HW, because I think LV will take them from the run-time engine.
Moreover, in my PC, where LV 7.1 is installed, the VIs that use this dll work fine, which means that LV takes the dll from the original path.
So, what is the problem for the EXE to take the dll from the same location as of the VI ?
I ve attached the screenshot of the non-corrupted lvanlys.dll to cross-check with someone about the size of it.
Can you please do me the favour ?
09-25-2007 04:53 AM
09-25-2007 07:09 AM
I guess you'll need someone from NI to help explain that build error, but just as a guess - are the read\write permissions OK? Do both locations exist?
Also, did you try manually copying the DLL into the data directory?
09-25-2007 08:27 AM
It has been a repair/reinstallation job for the umpteen time today. So, in my guess, it would ve set/reset the necessary file permissions to default. I had already tried the time-tested method of copying/pasting manually the lvanlys.dll into the "data" folder. After doing it also, I got the same error.
Normally, LV doesnt put these dlls intothe "data" folder, unlike what you told earlier [maybe in LV 7.0, but not in LV 7.1]. I m quite sure about that because the run-time engine takes care of all the necessary LV dlls required by the EXE [whether stand-alone or installed on a non-LV installed PC]. IMO, that is the job of the run-time engine, after all...
So, tomorrow as a first thing, I d contact NI to fix up this.
But any help from you is still much appreciated.
09-25-2007 08:41 AM
I guess you're right about that. Looking in the RTE folders on my PC, the DLL is there in 7.1, 8 and 8.2, but not in 7.0.
In that case, one other thing you can try is placing the DLL in the same folder as the EXE itself, but I'm not sure whether that would help either.
09-25-2007 08:50 AM
When I build my exe, which uses lvdaq.dll, it does put it in the data folder. You are adding the dll as a support file before starting the build aren't you?
Jim
09-25-2007 09:00 AM
