How to find average time taken by the data?
The averaging is fine, it is the Elapsed Time Express VI is the problem.  It is the wrong tool.  It is used only once and is in parallel to the the multiple iterations of the For Loop.
Look at the other functions on the timing palette.  You want to get the current time before the For Loop starts and the current time after the For Loop ends.  Subtract the values to get the time that has elapsed within the For Loop.
Message 21 of 42
(1,666 Views)
Hi GerdW, I have attached the LabVIEW file of your desired version.
thank you
Message 22 of 42
(1,656 Views)
I have attached my VI below. I try to use this method to find out the average data point but I don't get the average data point. What's wrong with this view. Could you please suggest to me the best idea to get the average data point of power as well as the time?
Thank you.
Message 23 of 42
(1,640 Views)
Hi prabesh,
Your "method" is basically this part of your code:
What does that code do?
  • The FOR loop iterates "n" times.
  • In this FOR loop the value of "Power" is added to a shift register: this basically is the same as replacing the whole FOR loop with a simple multiplication node!
  • The value of "Sum_power" is n×Power.
  • Then you divide "Sum_power" by "n" to get "mean_power":
mean_power = Sum_power / n = (n×Power)/n = Power
mean_power = Power
Is this what you want to achieve? Probably not.
But that is what you programmed - and what your VI is doing!
(Btw. doing simple stuff in a very complicated way is called "Rube-Goldberg"! :D)
You need to collect the last "n" samples of "Power" - as I have shown you (11 days!) before…
Message 24 of 42
(1,638 Views)
Dear GerdW,
Thank you for your prompt reply. I have some questions. I would like to ask you.
1. I Use shift register to add power. As power varies with respect to time. So, I think I will get the total sum of power. If the power is constant throughout time then I will get the same power. But I am curious to ask you that power is changing with respect to time. If I add variable power I should get a different power. But I am getting the same power.
2. The VI that was sent by you is not working.
Thank you for your attention.
Message 25 of 42
(1,627 Views)
Hi prabesh,
Yes, there was a bug in the example. You could have found that bug on your own in the last days…
I have explained why you get the "same power" instead of a "different power"…
(The way you wrote this question it is really hard to understand.)
Message 26 of 42
(1,623 Views)
Dear Gerdw,
Thank you for your reply. I did what you said to do, but I got the repetition data as shown below. I do not know why I got this. I am really working hard to figure it out, and now I am tired of working in LabVIEW. Could you please help me to solve this problem? I would be really grateful if you can help me.
Thank you in advance
Message 27 of 42
(1,576 Views)
Please attach your VI for LV2017…
Message 28 of 42
(1,571 Views)
Dear GerdW,
Thank you for your prompt reply. I have attached LV2017.
Message 29 of 42
(1,565 Views)
Dear GerdW,
I am a beginner. During one month, I learned a lot from LabVIEW.  However, the average data point is a hurdle for me. I learned many things from you. I hope the average data point will also solve.
Message 30 of 42
(1,561 Views)
