How to find closest value in array?
Hello all,
I just want to find the closest value from the string array. Which I attached herer as a image.
Now, If I want to find value 350 from string array and if it is not in array then in output array there should be display closest value of 350..
Thank You for support
Vinal Gandhi
Vinal Gandhi, CLA
(8,130 Views)
You will definetly have to better define "Closest" here. What do you expect if you have the value 349 and 351?
(8,125 Views)
Accepted by topic author Vinal_G
Hi Vinal G,
something like the attached comes to my mind.
Hope it helps
Mike
Message Edited by MikeS81 on 05-12-2010 09:31 AM
(8,123 Views)
