How to find parameters for an ellipse with some points of it's perimeter?
Hallo,
I have points in XY coordinates representing the profile of a tool. I'd like to approximate this profile to an ellipse and get it's parameters. From where do I begin? Which main concept should I follow?
Message 1 of 12
(5,214 Views)
i dont know exactly which parametres you have but possibly the fount of all knowledge
http://en.wikipedia.org/wiki/Ellipse
there is a section on the maths involved which could help you with the how to do it. if you can work out a method from this it becomes much easier in LV
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
Message 2 of 12
(5,210 Views)
I think Akiel is quite right. You should think how many points you need on this elipse, and calculate in a for loop the xy Points, bundle these points in a cluster, use autoindexing and give the output to the XY Graph. That should do the magic.
Any more question? Please fire away!
Message 3 of 12
(5,166 Views)
Thank you until now, but it didn't solved the problem yet.
Well, I already have the profiles plotted and I already wrote program that confirms that it is a profile from an ellipse. I wanted now to know which are A and B (the two radius of an ellipse) from the profile I have. I add here that I have around 900 profiles to evaluate.
I hope I was more specific right now, if is there any info missing, please, please, ask me.
Message 4 of 12
(5,156 Views)
Do you have only some sample points or the complete profile? Do you want to reach high accuracy or not?
Let's suppose you have the complete profile; the axes lenghts are the minimum and maximum distance between any pair of points on the border; so a rough method may be to compute such extrema. You don't actually need to calculate all the distances, only those belonging to approximately "opposed" pairs.
Paolo
LV 7.1, 2011, 2017, 2019, 2021
Message 5 of 12
(5,148 Views)
The main problem is that, I don't have a whole profile AND I don't know how much percent of the total the points represent. I estimate 10-20%.
Message 6 of 12
(5,138 Views)
That would mean you have about 0 to 70 Degree of the "circle" of Data points?
You already confirmed the structure is a Elipse. How did you do that, without calculating the semi-major and semi-minor axis? When you have these, you can use the standart equation:
where p is your poinz, f1 the vector to the minor axis, f2 the vector of major axis, and alpha the angle.
If you do not have calculated the symmetry axis, there is a itinerating tool which can do that.
http://zone.ni.com/reference/en-XX/help/370281P-01/imaqvision/imaq_fit_ellipse_2/
Note that this is an iteration! About the regression of an ellipse there is a long discussion going on and some papers have been wrote, because the least square fit is not very "trivial". The best solution I found turned out to be an eigenvector problem, and quite unefficient, I might add, nevertheless rather intriguing.
Message 7 of 12
(5,106 Views)
It wold help if you could attach a typical dataset so we get an idea of the problem.
Are the main axes aligned with the xy axes or can there be a tilt?
Are the data points sorted around the arc?
How much noise is there?
Message 8 of 12
(5,095 Views)
Here are the samples. X values in one file, Y values in another. If you plot them is easy to see that they form a profile. Those are 10 samples with 9 points each. That's I that I have and wanted to take the equation that defines the profile - not necessarily an ellipse, but I think it is a good approximation.
I don't know how much noise and how could I estimate that.
There may be a tilt.
Message 9 of 12
(5,056 Views)
Answering Johannes:
I made a program that calculates de center of a circle taking 3 points of the ellipse. If it was a circle, the points would be together (or at least randomly dispersed around a common point). The profile of these centers was in a "V" format, the same that hapens to ellipses.
Message 10 of 12
(5,053 Views)
