How to find the response of transfer function for different inputs?
If i have a transfer function H(s) = Y(s)/X(s) = 1 / (s+2),
How can i find y(t) for different values of x(t)? e.g if x(t) = sin (t).
Is there any function or vi in labview (control and simulation module) to do that?
please acknowledge.
Regards.
(4,073 Views)
This is a Math question, not a LabVIEW question.  Do you understand the relationship between a LaPlace Transform (the function of s in your question) and a time-domain function (a function of t)?  Do you know the relationship between the LaPlace "frequency", s, and sinusoidal frequency, f?  Have you ever seen formulas like s = i and 2pf = w?
To answer your specific question, you have only to substitute these identities into your question and do some algebra.  [You need to recognize that there is a frequency implicit in sin(t), of course ...].
Bob Schor
(4,053 Views)
I wrote sin(t), just as an example.
I know, inverse laplace and then convolving with any input will do it for me mathimatically but How to find inverse laplace using labview functions, i do not know.
If x(t) is a unit step function, y(t) will be exp(-2*t).
Please tell me how to do it using Labview (not only for unit step function but for any real time input)?
(4,036 Views)
Your transfer function consists of a gain element with gain 0.5 and a low pass filter with a corner frequency of 2 (radians per second).  I've not used the LabVIEW Filter functions, but I imagine that something like a simple low pass (one pole) filter should be there someplace ...
BS
(4,024 Views)
Thanks for your reply. finally i found my answer in control and simulation module and i applied different inputs to my transfer function.
Thanks again.
Regards.
(3,984 Views)
