How to find where local variable is defined?
The front panel control or indicator is the "definition" of a local variable. The value which is in that control/indicator when you open the VI is the value it is defined to.
To define a initial value for a control/indicator
- Write a desired value in the control/indicator
- Right click on control/indicator
- From the popup menu select "Data Operations -> Make Current Value Default"
Save VI and close VI.
Next time you open the VI the control/indicator will be show the defined value.
A global variable is defined in the same way, but the global variable will be represented by a control or indicator on the panel of a VI without block diagram.
If you create sub-vi's its also valuble to know how to set the default value of controls/inputs you may want to not always need to wire.
Message 11 of 12
(406 Views)
^ Now that seems like a bot.
Qestit Systems
Certified-LabVIEW-Developer
Message 12 of 12
(225 Views)
