How to find zeroes in a waveform?
I ran into the problem of finding the zeroes in a waveform!
I have two line segments and would like to get their intersection point.
But there doenst seem to be such kind of VI that could help me with this - does it?
The next thing I tried was to generate a formula for ech of the lines, then subtract them and find the zero of the resulting line and also generated a formula for it. I used the "Zeroes and Extrema of f(x).vi" to find the zero but it didnt work at all.
I also tried to generate a waveform of the resulting line (by subtracting the two line segments) to detect the position on the waveform where the Y-value is zero. But it didnt work either 😞
The sample intervall of all the lines is 12 and the zero value is somew
here between two samples. Maybe thats why it doesnt work! But how can i get rid of that problem?
(2,757 Views)
Hmmm... May be I'm wrong, but if you already can generate formulas for your line segments i.e. you have koefficients for line equations (using linear fit, I suppose), then why you don't want to calculate the intersection analitically using calculated koefficients?
(2,757 Views)
Attached is one way to do it, but you have to know a few things about the signals. You need to know the x value minimum and maximum. You also need a tolerance for the crossing value. And you need a step value for the analysis. As tolerance or step value increase, processing time decreases. The attached example creates 2 simple waveforms from formulas and then finds the intersection. It will also indicate if no crossing is found.
Hope this helps.
Dave.
(2,757 Views)
