How to fit to size to show the whole image in image display?
HI, I am using a control palette to display my video images using image display. However, the size is alway out of proportion. How do i show the whole image in the small box screen size. Basically how to fit to size for the images?
(4,045 Views)
This should do the trick:
Norbert
Norbert
Expert: Geometry
(4,041 Views)
Accepted by topic author fpaiy
You have that option in the Image Indicator itself. Right click the indicator you will get an option something like "Fit Image with Indicator" (Sorry I forgot the Actual name )
(4,039 Views)
The name is "Zoom to fit". Thanks.
(4,034 Views)
Ah.. Got it.. Thanks.. It was long before I was playing with those stuffs. 🙂
(4,031 Views)
Is there a trick for LV2010? A "Zoom to fit" function is nowhere to be found...
(3,924 Views)
