How to fix cursor at one particular value X?
Thank you for pointing it out. I removed the case structure. Now I am able to move the cursors and select the desired section in continuous mode.
One more problem I am having in this VI. Why the fitted curve using polynomial fitting is giving wrong Y axis values?
Message 11 of 14
(781 Views)
Accepted by topic author Ben121
"Wrong" is a useless word unless you tell us in what way it is wrong (not a good fit, missing, wrong size, wrong alignment, etc.)
I cannot test, because I don't have your data. To get the subset between datapoints of an array, use a locked to plot cursor, and the cursor index property  as follows. Note that the min&max function ensures that the cursor order does not matter.
Message 12 of 14
(770 Views)
This part of the discussion has been continued in a new thread. So follow the link.
Message 13 of 14
(754 Views)
Thank you for the replies. I think I am able to get it.
Message 14 of 14
(736 Views)
