How to fix error 1048
I am getting error 1048 in labview MATLAB script. If I remove the "data_demodulation" indicator (see red circle in the figure)  from the MATLAB script, I do not receive this error. But if I put "data_demodulation indicator on MATLAB script, I get this error. See attached image and vi.
I have seen several posts related to error 1048, but unable to find a solution.
Please guide me how can I fix it.
JK
(5,118 Views)
Move the bit where you define data_demodulate outside of the elseif statement.  It looks like if the elseif statement doesn't run then data_demodulate is never defined.
Even if the elseif statement runs, the conditional creation of it might still be causing your issue.
(5,084 Views)
Still the same error occurs. It does not work.
(5,072 Views)
Accepted by topic author josephkirmani
I solve this problem  my self by removing greater than operator from MATLAB script. And used labView greater than operator and now I am not getting any error.
JK
(5,055 Views)
