How to format a time stamp into string hhmmss?
I am going to use the time stamp as filename. I want the format should be HHMMSS. But when I convert the time to string, it always skip the zero. So, 07:01:01 becomes 711. (I wish it could be 070101). Any simple way to do it?
Thanks!
(4,340 Views)
You should be able to accomplish this pretty easily with the Format Date/Time String function, and "%H%M%S" (without the quotes) specified as your format string.
Good luck,
-D
(4,331 Views)
I don't know how you were doing it, but this is how I would go about it.  (Current time 2:25:45 pm)
You may have been using %#H%#M%#S, which removes the prepending 0's.
Message Edited by jasonhill on 03-17-200602:31 PM
(4,333 Views)
Thank you, guys. The reply comes so fast! I love this forum.
My problem is that I have only "seconds". I can convert it to date/time cluster. I pick only Hour, Min, and Seconds from that cluster  and build a string. Then I have the above mentioned question.
I know I can rebuild the time stamp and then format to the string. I also search and find the vi by tst. It looks like a complicated process. (Maybe not?)
I am just curious whether there is any easy way to work directly on the string. For example, I have 7, 11 and 1. How to get it as 071101? Any "string format" vi can do it just like that for time stamp?
Thanks!
(4,321 Views)
Rather than muck around with the timestamp functions, you can just convert straight to a string.  Note: I used the DBL conversion just so I could have an arbitrary # of seconds.
Message Edited by jasonhill on 03-17-200603:30 PM
(4,312 Views)
Great! That solves my problem.
Thanks!
(4,300 Views)
