How to format string 03-31-23 15:44 into a time stamp
@rolfk wrote:
@billko wrote:
Granted, but the original text in question does not contain this.
That’’s true, which requires one to make some assumptions. It is pretty safe to assume that such timestamps are in local time, the question of course is in which local time. CMT, EDT, EST or any of the other several dozen possibilities?
And do you really care? Let’s assume you got an isolated weather data set recorded at 13:37 in Tokio/Japan. Do you care if it was actually around midnight at your own location when that measurement was taken? Probably not, so it would be safe to treat the according timestamp simply as is and know that the measurements were taken after noon at the actual location.
But if it is an atmospheric measurement for instance, it may be useful to relate it to other measurements such as sun activity or similar and then you want to have an absolute universal coordinated timestamp. It may still be displayed in local time (the default for a LabVIEW timestamp control) but the underlaying timestamp is stored as UTC. And when converting external formats (ISO or not ISO) to a LabVIEW timestamp you have to consider these things.
That's what I was getting at.  "Considering those things" is not a trivial matter.  I wouldn't be sad if the world were to convert to UTC and do away with local time entirely.
Bill
CLD
(Mid-Level minion.)
Message 11 of 28
(1,830 Views)
@PhillipBrooks wrote:
See my signature...
Dang you beat me to it, that's what I was going to reply with.  The correct answer is the first one with Scan From String, but the other information given about time zones, DST, and other time idiosyncrasies should be considered.
Message 12 of 28
(1,820 Views)
Not really sure where you live. I could actually live with that 😁 (with only 1 or 2 hours time difference to the current situation). But for many people it would mean to go to bed at 14:00 and get up at 22:00 to go to work (or something along that line) 😂
Rolf Kalbermatter  My Blog
Message 13 of 28
(1,815 Views)
I'm -5 UTC, but whatever time you call it, wake-up time is still too early!  😄
Bill
CLD
(Mid-Level minion.)
Message 14 of 28
(1,788 Views)
I love Scan from String and Format into String.  But there is a perfectly good "Format Date/Time String" that takes a LabVIEW TimeStamp as input and outputs a String where Date and Time are formatted as the User requests (with the default being %c, the "locale-specific default date and time").  It even has a Boolean input called "UTC" that does who-knows-what ...
Bob Schor
Message 15 of 28
(1,773 Views)
@mshaska wrote:
How do I format 03-31-23 15:44 into a time stamp format?
Something like %<dd-mm-YY HH:MM>T
Qestit Systems
Certified-LabVIEW-Developer
Message 16 of 28
(1,715 Views)
%<%d-%m-%Y %H:%M>T actually.
Or %^<%d-%m-%Y %H:%M>T. This will assume the string is a UTC timestamp.
Both outputs are formatted the same (month/day/year 🙄), and are not UTC.
Message 17 of 28
(1,700 Views)
To scan UTC time from a string, e.g. 2023-06-07T14:30Z:
Use format string: %^<%Y-%m-%dT%H:%M:%SZ>T
To scan local time from string, e.g. 2023-06-07T15:30
Use format string: %^<%Y-%m-%dT%H:%M:%S>T
To format in to string, same as above
When viewing the time-stamp in LabVIEW the time displayed is in local time! it is not the actual value. The time-stamp internally is stored as the number of seconds since 1904-01-01T00:00. The time zone setting and  'adjust for daylight saving hours', therefore only effects format into string and scan from string, when local time is specified.
Message 18 of 28
(1,675 Views)
I think the ^ shouldn't be in the local string...
Message 19 of 28
(1,638 Views)
Sorry that was a copy and paste error, I believe you are correct:
I also didn't include seconds in my example strings.
To scan or format UTC time: 2023-02-17T16:20:00Z
the format string should be: %^<%Y-%m-%dT%H:%M:%SZ>T
For local time: 2023-02-17T17:20:00
the format string would be: %<%Y-%m-%dT%H:%M:%S>T
Message 20 of 28
(1,631 Views)
