How to generate PN sequence?
Thank you in advance.
Now I'm converting Matlab codes into a LabVIEW code. While doing it, I don't know how to generate a PN sequence that I generated on Matlab using 'commsrc.pn' or 'seqgen.pn' function. I searched some threads, and found out that the Binary MLS VI can generate it, but I'm not sure it will generate the same sequence or not. Can anyone help me with this?
(3,904 Views)
Does the PN sequence need to follow a particular distribution or constrain?
Kudos and Accepted as Solution are welcome!
(3,859 Views)
